From what I see, I can’t set the number of relays on the dashboard config tab. Is that correct or am I missing something?
I had to edit the configuration file manually to change the number to 1 relay.
It would be great to be able to do this from the dashboard.
Thanks!
Will do! You can assign different relays based on the number specified in the config file, I originally locked this down a little bit by keeping it out of the dashboard to avoid accidentally making breaking changes, but it should be able to be configured more easily and I’ll just put it behind a warning.
