When you increase the cropping value in the configuration, does that show up in the video feed?
I changed the values, and I didn’t see any changes in the video feed. The actual image processing might have taken that into account the cropped image, but I couldn’t see that visually.
By the way, at some point I made the cropping value 0.5 and that was throwing some kind of exception that was crashing the process.
Thanks for highlighting this - it should appear after starting detection I think. We had this issue with config setup and it should be fixed on the display-bug branch and also the USB issue from before. It now defaults to starting, and then just shows a warning if you want image recording with no drive detected.
Would recommend trying this out. It does also integrate with an app - happy to share the .apk if you’re interested in testing it.
Is this going to be merged any time soon?
Hopefully, but have been quite busy with a conference/getting the OWL3.0 going. It needs some finessing still before I merge it.
